Is it possible to map a shortcut to switch the asio config from 33/45rpm and vice versa when using time coded vinyl?
geposted Mon 20 Feb 06 @ 1:51 pm
its not possible to map a shortcut unfortunatelly but you can always go into the advanced configuration screen under the soundcard menu for TCV. From here you can change from 33 to 45 and back.
Best Regards
DJ White Devil
Best Regards
DJ White Devil
geposted Mon 20 Feb 06 @ 3:25 pm
