Hello!
I'm currently using virtual dj pro to play musicvideos. I have a m-audio delta 44 soundcard connected to a pioneer djm600. I also have a nvidia 6600 graphic card to output video.
I'm currently using a mouse and the keyboard to control virtual dj.
I am thinking about using the hercules dj console simpy as a controller for virtual dj, I don't want to use the soundcard features at all. Is it possible to set it up this way?
I guess it's possible to route the buttons, sliders and pots to other functions than the default ones?
I specifically want to assign the crossfader to only fade between videos. I also want to use the volume sliders as pitch controllers.
And now for the more advanced wishes, can I load a vst plugin, like a filter and control it with the pots?
Now that would be cool!
Dj Vinta, Norway.
Dj Vinta, Norway.
geposted Mon 20 Feb 06 @ 4:25 pm
I just realised that the crossfader and the volume controllers propably don't transmit any data, as it just controls the volume internally in the controller. Am I correct?
geposted Mon 20 Feb 06 @ 5:19 pm
Nope, not correct.. they are both asignable.
geposted Tue 21 Feb 06 @ 7:42 pm
I think it's just the MK2 thats asignable!!
geposted Wed 22 Feb 06 @ 1:49 pm
With MK1 and MK2 you can install the DJC Mapper v2.0 https://virtualdj.com/addons/view.html?type=sound%20effect (only for professional users) but i'm not sure if you can use the the crossfader to only fade between videos.
Try to ask this to djcel https://virtualdj.com/forums/44607/Plugins/DJC_Mapper_v2_0.html
geposted Wed 22 Feb 06 @ 1:52 pm
