Forgive me if someon has already requested this or there is a forum about it. I searched and couldn't find anything.
Would it be possible to implement this feature. A visual but mute wave pattern with a secondary beat lock?
For examples, some songs have arbitary wave patterns and are difficult to mix or use the majic wand for auto beat locking.
It's specially difficult to mix certain vocals to complicated beats. It would be cool if I could listen to a song first, click a key on beat for a while and have the software create and visible but silent wave pattern. Perhaps on a diffrent layer in diffrent color.
I could then take to songs with this silent wave patter and beat lock only on the silent wave patterns. That would sync the songs up just as easily as some techno songs do.
Maybe I'm nuts, but does this feature sound feasable?
geposted Mon 20 Feb 06 @ 5:58 pm
x_cite_houston,
Maybe you need to try VirtualDJ, Atomix MP3 is good, but has his limitations.
Sorry. I wouldn't be a problem here. I mark my Cue in the place that I'm going to let the song flow ... you can do it also I listen and let it go when it's time.. even I could mark the other song too. I have in that way control in the mix in the exact place. But I use VirtualDJ.
Update here: https://virtualdj.com/purchase/discount.html
try it here: https://virtualdj.com/download.html
geposted Fri 24 Feb 06 @ 4:17 am
