can i record using TCV's with Virtual DJ the same way i would not using TCV's??
geposted Wed 22 Feb 06 @ 5:54 pm
How do you normally record? rec out on the mixer to any source will do just fine.
geposted Thu 23 Feb 06 @ 3:25 pm
i record w/ vdj, and i was wondering if i can still record w/ vdj when i'm using the timecoded vinyls.
geposted Thu 23 Feb 06 @ 10:01 pm
yes you can still record using virtual DJ but make sure you send the main out (or booth out) from your mixer to a soundcard's line in. in the VDJ record settings chose the soundcard your mixer is sending to and make sure you select line in. it should work fine.
Best Regards
DJ White Devil
Best Regards
DJ White Devil
geposted Fri 24 Feb 06 @ 12:18 am
I got still problems with recording since the TCV. When i start recording, VDJ will recording both channels, even when i'm lisening channel 2 in my headfone. What do I wrong ?
My setup is:
2x mk2
usb maya 44
Behinger 700
THX Alois
My setup is:
2x mk2
usb maya 44
Behinger 700
THX Alois
geposted Wed 08 Mar 06 @ 9:39 pm
