Is it possible to assign a button to toggle between pitch bend/nudge and scratch using the jog wheels on the hercules mk2?
Also I find that when scratching with the mk2, after you release the jogs, there is a slight hold up/delay before the track resumes play, making your scratch sound off.
Any thoughts?
Thanks in advance.
Any thoughts?
Thanks in advance.
geposted Fri 24 Feb 06 @ 11:36 pm
any button assigning can be done with the dj console mapper..it's in the plugins section for download since you're a pro user.
and I KNOW!!! lol i experience the same delay when scratching with the jogs and i can't help but hate it.
geposted Sat 25 Feb 06 @ 1:54 am
With my skin you can change nudge or scratch with jog via skin button.
https://virtualdj.com/addons/download.html?addon_id=1612
geposted Sat 25 Feb 06 @ 1:21 pm
Thanks for your responses guys.
What I want to do is assign a button on the console (say one of the buttons between the jogs) that will switch/change the function of the jogs when it is pressed. The default mode could be pitch bend/nudge, and when the button is pressed, the jogs will function as a 'scratchwheel', if pressed again the buttons will revert the jogs to pitch bend/nudge. Hope I am making sense to you.
Is this configuration possible at the moment?
Btw, I have dowloaded the djc mapper and have successfully reconfigured my console.
geposted Mon 27 Feb 06 @ 4:04 am
Download this skin: https://virtualdj.com/addons/download.html?addon_id=617
I use this skin. Next to the vinyls on the skin the is a little button. with this small button you can switch between nudge function or scratch function.
Hope this will help
Hope this will help
geposted Mon 27 Feb 06 @ 4:01 pm
AND DON'T TRY TO SCRATCH WITH THE JOG WHEELS, ITS A WASTE OF TIME.
Anyway, jog wheels are perfect to nudge. (dont use that two pairs of silly buttons to nudge)
geposted Mon 27 Feb 06 @ 4:05 pm
