Two news servers have been added and 1520 listeners can now listen our radio at the same time.
The questions are as follows:
1/ Do you think that the upload should be 128 kbps (currently it is 96)?
2/ Would you encounter any technical problem (connection too slow)?
phenryll
phenryll
geposted Sun 26 Feb 06 @ 10:02 pm
1/ yes
2/ no
2/ no
geposted Sun 26 Feb 06 @ 10:03 pm
For information, if you want to stream at 128 kb, your upload speed bust be GREATER than 128, otherwise your bandwith will be used at 100% and you'll be disconencted from the server. We'd like to have the sound of the radio at 128 instead of 96, but each dj must check his connexion allow more than 128 for upload.
geposted Mon 27 Feb 06 @ 10:11 am
1) YES
2) Not now.
I got 256Kb of upload and at least I can do it with 128Kb ( I believe) we have to do some test I think, to ensure that we can trasmit at 128Kb without problems. We are going to need more power in our CPU than we use in 96KHz for sure.
2) Not now.
geposted Tue 28 Feb 06 @ 12:56 am
1) only have 128 so will have to test but i'm afraid of beeing disconnected
2) yes see 1)
2) yes see 1)
geposted Tue 28 Feb 06 @ 8:39 pm
We cannot allow some djs to play at 128 and others at 96. We had this problem at the beginning of the radio.
So if someone can't upload at 128 and stays at 96 everybody will have to stay at 96.
geposted Fri 17 Mar 06 @ 12:36 am
