Topic: MIDI mappable crossfader
Does anybody know of a company that does or will make a MIDI mappable crossfader that could replace a standard xfader in a standard mixer? I'd like to be able to control the xfader on VDJ to mix video the way I want. I don't want the Hucules because it is not rack mountable, but it does work exactly as I'd want it to. If only it were rack mountable... If the DAC-3 had a built in fader, it would be perfect, but it doesn't.
geposted Mon 27 Feb 06 @ 10:37 pm
I believe you can already fade the video with the dac-3 and the new mapper
You can also buy any cheap analog joystick and use its electronics.
I can create a HOW-TO. When you push the button 1 on the joystick, one
axis is used as crossfader. It worked for me in VDJ.
So you just have to put it into mixer somehow.
I am new to virtual DJ and I am trying to map the xfader on my Livid Tactic m2 controller to Virtual DJ, is this possible? do you think i can run Tactic Pro and Virtual DJ together?
