Forum: Wishes and new features
Topic: Saving DJ Interaction / Mix
dj_uubHome userMember since 2006
Well guys, this sounds BIG!!!
Let's say that i'm planing and preparing a mix at home, and i'm previewing it, i'll loved that VDj can register all my interaction, do you know what i mean?
Let's put it this way, so i'm playing a song, at the same time preparing another to mix, cue points have being setup, at the right time transition between song has being made and later, effects, loops and other stuff has being added to the mix. Now, what i want is to register all what hapens, so later, i can open the file and play it without any interaction, or even correct it.
It might've been easier to save the mix in a wave file, but that will limit the dj from correcting his mix, like resync tow songs or add another one, or other stuff.
geposted Tue 28 Feb 06 @ 11:03 am
Dj XeoPRO InfinityMember since 2005
If you want to do that get mix meister or something. or better than that a proper sequencer. It would be a handy feature to ahve for those people making mixtapes or something but for most it would be something that ppl dont want cluttering up the program.
geposted Wed 01 Mar 06 @ 3:14 am
