Hi this is Lucio, I want to know how I can add a Maya 44 usb or regular Maya 44 multi-chanel sound card to work with this program Thanks
geposted Tue 28 Feb 06 @ 9:52 pm
you must choose 4.1 Soundcard or Advanced Config for the sound, if you aren't using the TCVs
or you must choose ASIO Soundcard (last of list) if you are using TCVs.
geposted Wed 01 Mar 06 @ 5:00 pm
