Well, I have downloaded and installed the update but cannot see any differences. Could someone please post a list of changes from 3.3 to 3.4
geposted Thu 02 Mar 06 @ 6:13 pm
it's a TC fix
new features:
improved timecode sound
new TCCD mode (compatible with cue, loops, etc)
timecode autocue (move the needle from more than 1mn jumps to the next cue)
timecode smartpitch: apply mastertempo from turntable pitch changes
new timecode options: force absolute/relative mode, change lead length
new action: clone_deck
new action: unload
bug corrected: negative length on big playlists, cue markers out of range, forced automix just before automix point, ...
new features:
new action: unload
geposted Thu 02 Mar 06 @ 6:17 pm
But no fix on the visualisations not working if using advanced soundcard options :((
geposted Thu 02 Mar 06 @ 6:32 pm
how do you clone the deck?
geposted Fri 03 Mar 06 @ 4:12 am
create a shortcut
geposted Fri 03 Mar 06 @ 4:47 am
I guess I'm an idiot but i looked in the shortcuts & don't see this as an option. Please explain further.
geposted Fri 03 Mar 06 @ 6:07 am
You can find the new clone_deck and unload in the shorcut via keyboard. http://img45.imageshack.us/img45/5492/immagine7oo.jpg
geposted Fri 03 Mar 06 @ 8:34 am
The function unload() free the memory allocated for the song into the deck. It's great to get better performance ;-)
The function clone_deck() will load the same song on the other deck and play it at the same position
geposted Fri 03 Mar 06 @ 9:20 am
