Forum: Old versions
Topic: Hercules MK2 and CUE Points
Hi!
I've the MK2 and having problems with the CUE function:
The buttons 1,2,3 when CUE enabled (no matter wich player -A or B- I use) work the same way:
1: CUEs or Plays CUE number 1 for deck B
2: CUEs or Plays CUE number 1 for deck A
3: CUEs or Plays CUE number 1 for deck A
I updated to latest drivers from Hercules and using VirtualDJ 3.3.
So I've the new HERCULES SYSTEM PANNEL, wich can check for newer drivers itself, and says I've the latest ones.
I contacted Hercules Support a week ago and no answer.
Searching at FORUM I found another user with same problem who told something about a Hercules DJ Console Mapper, I wrote there but no answers...
https://virtualdj.com/forums/44525/Hardware_Technical_Support/_HDJC2_Problem_____Help.html
Thanks in advance
geposted Fri 03 Mar 06 @ 9:34 am
