Topic: DJ Laptop
Just recently purchased Atomix Virtual Dj. Don't quite follow the instructions. The beatlock doesn't seem to work for me. Any suggestions.
geposted Sat 04 Mar 06 @ 12:34 am
Let me see if I understand.......
Load a song in the left deck, it scans and you see a BPM...maybe 130 or whatever, pitch stays in the middle
Load a song in the right deck, it scans and you see a BPM...Hopefully 130 or whatever to match the left deck, the pitch moves accordingly to "match" the left deck.....
If this does not do this automatically, you can try going into the FAME settings under "Config" at the top of the deck, then make sure "AUTO BPM" is enabled and try again....if you want to do it manually then right click on the "BEATMATCH" button on the deck
Hope this helps
