I've just purchased VDJ pro and downloaded the program...it was working fine...then I've downloaded some skins and those worked as well (15-20 minutes)
I've close the program and I tried to open the program again...it tries to open then it minimizes itself and goes to the buttom of the screen I try to maximise (ope the program) nothing happens.
I am not sure if I was able to explain myself well, I hope someone could guide me so I can start enjoying my VDJ.
geposted Sat 04 Mar 06 @ 8:28 pm
just try to restart windows. if it won't help you, reinstall VDJ.
oh yes, and welcome in VDJ world ;) hope you will solve the problem
geposted Sun 05 Mar 06 @ 12:56 am
also make sure you have the latest version of DirectX (9.0c)
geposted Sun 05 Mar 06 @ 2:01 am
It's certainly the size of your screen which isn't compatible with the skin
geposted Sun 05 Mar 06 @ 12:56 pm
To add: Make sure you dl the proper resolution skin for your system.
To fix: Go the VDJ program file, c:\ program files \virtualdj \skins folder and just delete the skins that are the wrong resolution. When you reopen the program it will load up the default skin which you can then change to the proper sized skin.
geposted Sun 05 Mar 06 @ 1:11 pm
