Hi,
I am trying to find a graphics solution to use with a laptop for video mixing because although the laptop has an S-video out port, it only works in clone mode (ProSavageDDR graphics).
The only solution I can find so far would be a video editing system, the Pinnacle Studio Plus 700 USB edition which contains s-video out.
(http://www.savastore.com/productinfo/product.aspx?catalog_name=Savastore&product_id=10284318&pid=45&tid=279)
Would VDJ be able to pick this up and output to the S-video port on the Pinnacle card while continuing the main display on the laptop screen, although I realise I may be pushing the system resources with this especially as I already have a simple USB sound card for headphones.
If anyone has any better solutions other than replacing the laptop I'd very much appreciate any advice
thanks,
James.
thanks,
James.
geposted Tue 07 Mar 06 @ 12:23 am
If you only want one output use your vga monitor output
geposted Wed 08 Mar 06 @ 2:25 am
Using the monitor output you can swith it as a second video output and can select extended mode to this display.
Good Luck!
Good Luck!
geposted Wed 08 Mar 06 @ 11:48 pm
Sounds like a perfect solution, except the laptop graphics card is a ProSavageDDR which doesn't seem to support extended mode :-(
geposted Fri 10 Mar 06 @ 2:45 pm
jamesmcneil,
Sorry to heard that... In my expirence the real solution is to change the laptop. because the Laptops are made all in one, you cannot upgrade the graphics card only, so you need to remplace you current notebook.
You can have some nice Dual-Core or even AMD FX60 notebooks with N-Vidia 7800GTX a board...
Very good to work fast and good...
good Luck!
good Luck!
geposted Mon 13 Mar 06 @ 3:17 am
