I work in a little crap bar and I just want to set up a playlist and auto fade between the songs in my playlist. No need to worry about beatmatching. When I use auto mix, the crossfader shoots back and forth so fast theres no natural sounding fade. please help ou.
geposted Fri 10 Mar 06 @ 4:42 am
Maybe you can't change the parameters of the crossfader, in the trial version. Did you try to change in config?
geposted Fri 10 Mar 06 @ 9:35 am
I have a full version---dont see what to change in config...tried different options--no luck. I feel like a retard
geposted Fri 10 Mar 06 @ 11:38 am
If you have the full version please insert the serial number here https://virtualdj.com/fusers/modifuser.html
geposted Fri 10 Mar 06 @ 11:51 am
I have the full version and found this thread on a search for "playlists". I'm also looking for the best way to automate a playlist for "cocktail hour" social hour events, that sounds best, and doesn't cut off intros or outros from the songs.
Best suggestion so far: set crossfader to "full" and set fade time to 2 seconds. Any other suggestions? Can the parameters for automatic playback be further adjusted?
geposted Wed 26 Apr 06 @ 5:44 pm
