Forum: VirtualDJ Skins
Topic: JB - 706106 - XL - Page: 1
New skin comming soon.
for picca see my blog.
1280 x 1024 res.
geposted Sat 11 Mar 06 @ 9:43 am
looks good so far.
Also working on a multi instance skin (in my blog to)
Very good work Jedi Master djjb!
One quick question djjb,
i think when in multi-instance, we can use either browser to load music on one or other instance. Why wouldn't you make a multi-instance skin with only ONE browser but 4 decks. Or make a hidden Browser that will be under the screen and hidden.
This would be really good.
Jérémie
It's looking really nice (particullarly the single instance skin). Too bad there's not a 1024 x 768 version offered
@ mcouture...
I will make a 1024-768 later.
thnx all for your possitive replies.
updated picca of the multi instance in my blog.
any sugestions ?
Put the up CBG indicator down in the center and the down in up, like multi-istance from djcel.
This is good to mix one up song with one loaded in the second down VDJ and I think it's good to modify the color bar of title,artist,ecc, light gray and white is not easy to see, try black gray.
And where is the loop area? I think is good if you use one hidden panel to put inside.
it's not finnished yet cioce.
i didn't do anything in the browser.
loop works the same as default-skin.
will change the cbg.
thnx fot reply
Very Nice and useful!
Thank you
It's possible to make aresolution 1280x800? (for laptop users)
Bye
1280 / 800 pxl is done
upload today at 20.00. hour
thnx
Great notice!
i am waiting to donwload to start using for this weekend
See you
thanks
there is a bug with the pannel-buttons.
already corrected and uploaded.
activated too ;-)
this is the best skin I have seen by now, I would like to slightly modify it to fit my personal needs, but after considering the time it will take to learn how to make one by my self I thought I won't finish it before I die.........:).......so I was thinking if you (djjb) can make some adjustment, if you have time and the wish to do that.
I thank you anyway
PS: for the developers........after trying different software I decided Virtual DJ suit for me......I know I didn't buy it yet but......I'm saving the money to buy your piece software.
Thank you.
the picture on the download-page is gone ?
tell me paulrain
51%
