maybe a stupid question, but i am trying to rip my vinyl collection. but do I have to change something in config or can i use the default settings. because the line you see, doesn't move much. or do I have to change the bitrate?
geposted Mon 13 Mar 06 @ 8:11 am
if the line doesn't move much its because rip vinyl isn't properly configured.
Here is what I recommend. Connect your TT to your mixer or directly to your computer's soundcard's line in.
what kind of decks are you using? if you require a pre amp check the VDJ config options and check pre amp.
make sure that if your TTs require a grounding you should ground the TT properly.
also make sure the right soundcard is selected in the config panel of rip vinyl.
If your still having problems let us know
DJ White Devil
DJ White Devil
geposted Mon 13 Mar 06 @ 3:27 pm
i connected my tt to the line in on my maya44 usb and in the config I selected the maya input.
but when i switch the gain the lines are moving but how much can I put the gain up for good quality? or is it a matter of experience and listen afterwards to the track.
thx for the help
thx for the help
geposted Mon 13 Mar 06 @ 11:28 pm
