Where can one find the timecoded cd's and the XP10? It seems that from the VirtualDJ site you can only buy TCV and the software.
geposted Tue 14 Mar 06 @ 11:23 am
You can download the time code CD here: https://virtualdj.com/products/timecode/VDJTimeCode.mp3
and buy the XP10 here
http://eks.fi/index.php?page=xp10_order&PHPSESSID=855838c9034dcecd03b6c308c3b00bd3
For the next time try to use the search button on the top and google!
geposted Tue 14 Mar 06 @ 11:24 am
Thanks for the info.....
geposted Tue 14 Mar 06 @ 12:23 pm
what is the time coded cd made for?
is it for the fully digital mp3 based tables?
thanks
thanks
geposted Mon 10 Apr 06 @ 5:39 pm
time coded cd is made for using vdj from your cd players.
geposted Mon 10 Apr 06 @ 5:48 pm
You get nothing but a quicktime page with hissing to find the cds..so how do we find it>
S
S
geposted Sat 15 Apr 06 @ 4:53 pm
Uhh do you mean the quicktime page with hissing is a sound? The timecode is the wierd hissing sound, burn that to a CD, and put it into the turntable thing, then use it with vdj.
geposted Sat 15 Apr 06 @ 10:29 pm
right click on the link and save as. This way you will be downloading the TC signal. just burn that as an audio CD and your set.
Best Regards
DJ White Devil
Best Regards
DJ White Devil
geposted Sun 16 Apr 06 @ 12:18 am
after i burn the timecode to a cd as an audio file how do i hook up my numark cdx to the computer like which wires to i hook up to my soundcard to beable to use vdj and my turntable like toghether like scratch music off my computer and shit? thank you.
geposted Sat 06 May 06 @ 6:37 pm
but you need the full version of VDJ ;)
geposted Sat 06 May 06 @ 6:46 pm
