1. is it possible to hook up the xp10(if poss. 2 of them) to the nuo4
2. can you hook up the nuo4 to a pc, like an xp10
3. is it possible 2 hook up the xp10 to a pc and to a nuo4 while the nuo4 is connected 2 a pc(If possible)
4. how much does a nuo4 cost and why cant i buy the xp10 or the nuo4 from here
sorry 4 all the questions but if answered i'd appreciate it
geposted Wed 15 Mar 06 @ 8:54 am
1. Nuo4 is a four channel mixer, so yes you can hook up 2 xp10 to it.
2. Yes the Nuo4 has a USB port to plug in to your computer to control VDJ with midi.
3. Yes, the xp10 and nuo4 will be connected to the compuer through USB and the xp10 will be connected to the nuo4 with RCA cables.
4. http://www.eclerdjdivision.com/instruments/nuo/nuo4index.htm check this site for more information on nuo4.
Nuo4 is a product from Ecler, it cannot be selled on this website. And for xp10, Atomix Productions is out of stock for the VDJ version of xp10.
geposted Wed 15 Mar 06 @ 11:50 am
does anyone know when atomix will get some more xp10s,
oh and do you need to install any software to use the xp10 and the nuo4 on vdj
geposted Wed 15 Mar 06 @ 8:39 pm
I don't think they will ever get more xp10.
you can buy xp10 on other websites, they will work just as well.
geposted Wed 15 Mar 06 @ 8:48 pm
that sucks i like their design
geposted Wed 15 Mar 06 @ 8:49 pm
The only difference was a virtualdj red and black sticker on the platter.
geposted Wed 15 Mar 06 @ 8:59 pm
i liked that, i woundnt know where 2 get a sticker like that where i live
geposted Wed 15 Mar 06 @ 9:16 pm
impossible to get. But you could make it yourself.
anyway for the moment you don't have xp10 so it isn't really the question.
geposted Wed 15 Mar 06 @ 9:22 pm
do you need to install any software to use the xp10 and the nuo4 on vdj or does vdj automaticly detect the hardware
geposted Wed 15 Mar 06 @ 10:39 pm
for VDJ nothing to install.
For nuo4, if you only want to use it as a regular mixer nothing to install, but if you want to use midi you must install nuo4 drivers.
geposted Wed 15 Mar 06 @ 11:28 pm
