when I start playing a tcv after 32 beats it starts back at the begin. Anybody knows how it comes.
And how can i restart my song from the begin because when i put my needle up and put it back to the begin of the song, it plays from the point where i put my needle up. maybe a wrong setting?
my tcvs are in the smart mode. please anyone can help me?
geposted Thu 16 Mar 06 @ 12:33 pm
remove anti-skip in the soundcard settings.
If after 32 beats your song restarts check to make sure your loop isn't active.
Best Regards
DJ White Devil
Best Regards
DJ White Devil
geposted Thu 16 Mar 06 @ 4:09 pm
if needle drop is not working you may not have good timecode quality. try looking in timecide options while the TCV are spinning to see what quality is
geposted Thu 16 Mar 06 @ 11:48 pm
Xeo, the quality is 100%. but the problem is when I lift the needle for example after 2 minutes in the song and put it back in the beginning of the song, the song starts to play again from the second minute. But I didn't try the option from white devil yet. I'll try it tomorrow.
geposted Fri 17 Mar 06 @ 2:12 am
Try your settings in absolute mode instead of smart mode in VDJ->SoundCards->LowLatencyMode->Config TimeCode->Options->Mode->Absolute.
Good Luck!
geposted Sun 19 Mar 06 @ 4:45 pm
