Hi,
Is there any way of changing the font size in the music database? I run using a homemade console that has built-in pc, deck controller, mixer and monitor, only the monitor is rather small, around 7 inches across. This was fine when I ran PCDJ Red, which was originally designed with 800x600 in mind, and so has decent sized fonts. I see VDJ has an 800x600 skin, but the fonts in the music library are still too small to read comfortably - is there a way around this (other than getting a bigger monitor!)?
thanks
John
thanks
John
geposted Thu 16 Mar 06 @ 12:53 pm
Make a search on this website and you will find how to change the size in the xml file of the skin
geposted Thu 16 Mar 06 @ 2:32 pm
