hey i just got the trial for virtual dj and when recording in the burn cd do you just put a blank cd in and it will automaticly record when your mixing??
geposted Thu 16 Mar 06 @ 3:56 pm
No it will create two files, a .cue and a .bin file. These are CD images, and you will then need a burning software to burn the CD.
geposted Fri 17 Mar 06 @ 12:20 am
ohh ok so then do yu burn both the cue file n the bin?
geposted Sat 18 Mar 06 @ 12:53 am
Yes, you can even do mixed cd's this way, using the crossfader you can create track indexes
in the cue file..
in the cue file..
geposted Sat 18 Mar 06 @ 2:36 am
