I'd like to see a speed adjustment option in config, where you can adjust the speed of the crossfader when in automix mode, if you play a few music videos one after another it can be pretty effective if you do a quite slow sweep with a good transition, ie satellite. Should be easy for the dev team to implement and I'm sure others would want it.
geposted Fri 17 Mar 06 @ 7:25 pm
If you activate Force Fade, you can use the little slider for autocrossfading time.
this is in FAME settings.
geposted Fri 17 Mar 06 @ 7:34 pm
