i downloaded the trial ver. for some reason it run properly or i did or am doing something wrong.
any help wouid be great...
geposted Sat 18 Mar 06 @ 9:02 pm
Hi, which problem do you have?
Does it close after being opened for 2 minutes?
Does it open but it stays on taskbar and doesn't show up?
geposted Sat 18 Mar 06 @ 11:23 pm
task bar and dosent show up..
geposted Sun 19 Mar 06 @ 5:53 pm
What is your screen resolution? If it is 800x600, then you should change it to have 1024x768 because VirtualDJ no longer supports 800x600 screens.
geposted Mon 20 Mar 06 @ 8:58 pm
