When I need to cue up the next song, the only way that I can do it is if I put my slider for that second deck all the way down in order to be able to avoid my listening audience from hearing it, any suggestions on how to be able to do this without having to lower the channel slider?
geposted Sun 19 Mar 06 @ 11:29 pm
if ur sound card can handle 4 channel make sure u have it set that way on the sound config then just plug ur headphones to the line in which becomes rear out on a 4 channel config (some sound cards)
or if ur using a 2 channel soundcard and a splitter remember only one side suppose to go to the amp the other is for ur headphone so split it left and right find what is cue and what is main and plug in to the amp accordingly (just buy an adapter to make the single channel into 2 )
This is so much easier with a 4 channel capable card
geposted Mon 20 Mar 06 @ 1:50 am
