All,
I downloaded the custom DAC-2 mapping and love the features, however, there is one that I would like to change.
When I use the Pitch Bend -/+ it controls the amount of loop beats (1,2,4,8,16)
If I hit Shift -/+ it applies the pitch bend.
I would like to have these two functions reversed! I use the Pitch Bend much more often than loops and life will be much easier if this can be changed! I've looked through the forums and have not seen a direct way to change this for the DAC-2. Is there a GUI interface somewhere?
Thanks in advance,
Woody
Thanks in advance,
Woody
geposted Tue 21 Mar 06 @ 4:00 am
Same here! I also use the DAC-2 and would lik that part reversed!
Thanks!
Thanks!
geposted Wed 29 Mar 06 @ 12:49 am
Me too. I suspect that the person that created the plugin uses timecoded vinyl, thus has no need for pitch bend. I'm hoping for some help on how to create plugins for Virtual DJ that will use the best features of both the default mapping, and the plugin. The pitch bend button is first on my list!
geposted Thu 01 Jun 06 @ 3:48 pm
