anybody help me pls.... i am thinking how to listen music in deck 1 and deck 2 separately.
geposted Tue 21 Mar 06 @ 5:42 pm
this isn't possible with the trial version. But the professional version will let you use up to 32 different soundcards.
If you have a usb or pcmcia soundcard with 2 stereo outputs you will be able to you use it with your laptop on VDJ and having deck1 & 2 on separate channels.
geposted Tue 21 Mar 06 @ 6:16 pm
In the trial version can i play zip files karaoke
geposted Sun 26 Mar 06 @ 2:14 pm
Yes you must add the zip extension to Karaoké/Zip decoder in Virtualdj Settings->Extensions Tab.
But this is not the subject of this topic.
geposted Mon 27 Mar 06 @ 1:40 pm
