Hi,
I am a very new user. I looked for the answer to my question but haven't been able to find it. With Automix turned on, I would like to edit the Entry and Exit points. I go to the place in the song where I want the new entry point, go into the Manual BPM window and under the Edit Automix tab I click on Set Entry Point. The Entry Point marker moves to the new location but as soon as I click OK the marker goes back to the original place.
What am I doing wrong?
Thanks
Thanks
geposted Tue 21 Mar 06 @ 8:15 pm
You must sent entry and exit points for each type of Automix (Fade Cut Tempo)
And if force fade is activated in VDJ settings then desactivate it.
geposted Tue 21 Mar 06 @ 9:09 pm
Hi and thanks for the reply.
Unfortunately, I still get the same result. I deactivated Force Fade, and tried to save the new entry point at the very beginning of the song in all 3 types of automix. As soon as I clicked OK, the entry point went to about 10 seconds into the song. Any other ideas?
Thanks
Update ... I think I have found the problem. The changes are made but they don't appear until the next time the song is cued up.
geposted Fri 24 Mar 06 @ 4:27 am
