Can someone please create a plugin that jets, flanges, and pans(adjustable) at the same time, thats one effect i was hoping vdj had.Ive tried combing effects to make a simmilar sound effect but it does not sound like i hoped. Please create that plugin id apreciate it.
geposted Tue 21 Mar 06 @ 10:45 pm
Could you precise adjustable at the same time.
Because you can not have jet and flanger at the same time. Jet is a flanger without LFO on delay.
Otherwise, did you try Jetlag V2?
geposted Wed 22 Mar 06 @ 6:01 pm
when i say adjustable i mean u can tune it and activate the effects(for example the pan flanger you can activate on and off) like on most of the effects but i didnt know that the jet is a flaner without the lfo. well i guess that the flanger on vdj is not the same that ive heard on other turntables. but can you make a plugin that flanges and pans but with a jet that auto tunes(tunes down and goes back up and down again and so on with an adjustable jet tuning speed, that will go down and up slow or fast or how you choose) please try to make this plugin its all that im lacking, if i could make it i would but i do not know how
geposted Thu 23 Mar 06 @ 2:43 am
