I upgraded (Clean install) to XP and reinstalled VDJ...my skin saves but my sound card settings dont save. Does anyone have any ideas?
geposted Wed 22 Mar 06 @ 3:07 am
Are you administrator of your Windows XP? if you aren't that could be the reason why the settings don't save because they are saved in the registry and non-administrators can't change anything in registry.
geposted Wed 22 Mar 06 @ 10:11 am
i had to uninstall and re-install..now it saves. Now i have a new problem not sure if its beacuse of XP or Asio drivers. but after about 15-30 minutes of play VDJ stops playing..if i change to the standard win sound drivers and back then it works again. also now even while it is playing ok..the directory search gets garbled..any ideas ?
geposted Thu 23 Mar 06 @ 4:12 pm
