Hi,
Don't know if this is intentional or a real bug.
I have noticed that when in "local database" I sort by "artist", etc...., then I scroll down.
If for some reason I choose to delete a song no matter where I am in the list after it delets the song it looks like it refreshes and puts my cursor back to the top of the list.
I then I have to re-sort, and scroll back down again.
If there is any way to fix this, I would greatly appreciate it.
-Thanks, Dj Los
-Thanks, Dj Los
geposted Wed 22 Mar 06 @ 3:51 pm
Your talking about the playlist ? anyway it happens on playlist too.
That's very annoying i "suffer" from this too...
geposted Wed 22 Mar 06 @ 7:04 pm
it also resets/refreshes if you edit the file.
If you delete the song, it should just move you to the song above or below, not refresh/reset.
If you rename a song, it should refresh but your cursor on that song, not reset/refresh.
-Thanks, Dj Los
-Thanks, Dj Los
geposted Sat 25 Mar 06 @ 4:26 pm
found more:
same thing but this time scroll down and rename a song hit ok, list resets again, scroll down to that file, and nothing was changed, now thats really annoying....
here is the post of the other one:
https://virtualdj.com/forums/48030/Bugs_report/Rename_not_displaying_in_browser.html
-Dj Los
-Dj Los
geposted Sat 25 Mar 06 @ 8:06 pm
Yes, I agree. This is a persistent aggravation...
geposted Sat 22 Apr 06 @ 11:45 pm
old problem yes :)
hope it will be corrected in next version.
geposted Sun 23 Apr 06 @ 8:50 pm
Its beeing worked on ;) Not sure if it will make it for this release, but hopefully
geposted Sun 23 Apr 06 @ 11:31 pm
