Virtual Tech's do you think you could add a key changer for karaoke? I am asked alot to change the key but can't do it because there is not one. Let me know what you think of this idea..
Thanks,
Corey B
Thanks,
Corey B
geposted Thu 23 Mar 06 @ 9:55 pm
There IS a key shifter that does the job... it is a bit buggy (in my opinion) when there is no audio or low volumn audio... but it does work in semi-tones. Look for "Keyshifter" in the plugins section.
If this doesn't work for you, VOCOPRO (and I hate to recommend them) have a rackmountable device that will change key as well as a few mixers with fx, behringer comes to mind.
geposted Mon 27 Mar 06 @ 7:50 am
