Maybe that's a post for Guillemot friends but...
Are you thinking about a solution for extreme dial's sensibility of Dj Control hardware.
Maybe a "multiplicator" in Virtual DJ (something like 360 degrees = X*0,001 seconds) or 3 posibilities (sensibility: Hi, Lo, Med).
It's impossible to enjoy mixing when you "touch" a dial and the mix go away.
My english is very bad, sorry.
Thanks
Thanks
geposted Fri 24 Mar 06 @ 6:45 pm
...Or take the console to bits, and wire a switch in series with the sensor circuit on the jog wheels. That way, you could just switch the wheels on when you needed them, that would solve the "knocking the wheel accidentally while in a mix" problem!
geposted Fri 24 Mar 06 @ 9:46 pm
turntabels are awesome
geposted Tue 28 Mar 06 @ 10:02 am
this is 2 throwed
geposted Tue 28 Mar 06 @ 10:03 am
