I recently thought about ripping my vinyl collection using rip vinyl, that came with vdj. The thing is i get this error about it not being able to save the recorded file. [Impossible to save file] error appears, so is it me? Or the program, i imagine its my problem and not the program at fault. Cheers for any help guys.
geposted Fri 31 Mar 06 @ 4:17 pm
Does anyone know why this error message appears? I understand this has happened before to others, so i know its a fairly common problem. ^ ^
geposted Sat 01 Apr 06 @ 8:45 pm
Im definitely getting a signal from the recording, with the lines quite busy. Im using a tt that requires an amp and plugging it straight into the pc's line in connecter, im checking the RIAA preamp aswell in the config menu. Anyone else had the error message though when saving a file? What are the solutions to this minor problem, thanks.
geposted Sun 02 Apr 06 @ 4:43 pm
did you check the bit rate?
geposted Tue 12 Sep 06 @ 4:24 pm
