Hi, Im using VDJ with DJC MK2 and DJCMapper. I just selected mixed mode for MK2 to be able to play an external source, but when i press the "Audio Source" button i cannot listen to the external source (the green light turns on and off, but nothing else happens). If I remove DJCMapper it works ok, so I figure its something I´m making wring with the plugin. What "action" and parameters should I select for the "Audio Source" button in DJCMapper? Currently I have "select" and 0 as a parameter, Absolute Value
Thanks a lot,
ReTango
Thanks a lot,
ReTango
geposted Sun 02 Apr 06 @ 5:25 am
The correct topic is here
https://virtualdj.com/forums/44607/Plugins/DJC_Mapper_v2_0.html?highlight=mapper
geposted Sun 02 Apr 06 @ 11:43 am
