Hi, whenever I use TCV with VDJ 3.4 I get incorrect pitch and bpm readings. My turntables have quartz lock so I have that set, therefore the pitch should be at 0% in VDJ however it is always at -8.4% with slight fluctuation. Changing the pitch on my TT to actually be at +8% makes VDJ read -0.1% with some fluctuation.
The bpm is also displayed wrongly with the pitch although the key seems to be right, I have time stretch disabled.
I requested a full installer of 3.4 which mp3jrick sorted me out with very quickly but still have the same problem. I did a full uninstall and then removed all related folders and registry entries using three different registry tools. I have planned to format my PC but will do so later this week.
For now I'm using 3.3 with no problems. Does anyone else have similar problems? For my ASIO soundcard I'm using the HDJC2 with the latest drivers and software (I have tried reinstalling these).
I don't suspect the rest of my hardware to have any issues especially as I'm not using my integrated Soundstorm 2 chipset for audio.
Thanks.
Thanks.
geposted Thu 06 Apr 06 @ 4:08 pm
Managed to troubleshoot the problem a bit further. This only occurs when using the HDJC2 in 48kHz mode. However, this mode allows for a lower latency to be used so is the desired mode of operation. 44kHz mode is fine.
geposted Thu 06 Apr 06 @ 8:07 pm
Virtual DJ dont fully support 48hz ... YET..
So, until the upgrade, you need to use 44...
hope that helps:)
hope that helps:)
geposted Thu 06 Apr 06 @ 8:14 pm
