I prepare actually a guide for VST but for you I give an information before the launch of my guide, i have discover today a very good free effect:
http://www.askywhale.com/vst/
Mp3play VST
It can read mp3 song, ok you said VDJ read mp3!!!!! But this plug in is very good and can efficently using in your mix, i love this effect it is very very good!!!
To load a song in this plugin, clic on the first button on the top.
You can create a m3u file with all your jingle and use in the mix very easy and create a loop or use equalizer!!!!
It's good no?
Caution this plugin use memorie!!
For my guide i want your suggestion then post in this forum a lot of information, thanks
Ciao Ciao
U115
Mp3play VST
It's good no?
Ciao Ciao
U115
geposted Fri 07 Apr 06 @ 2:34 am
