Hi to all,
I have a trouble: I'm trying to sample a loop from a track that I have to pitch up (from 140 Bpm to 160 Bpm). I've actived the Time Stretch option in the FAME settings to avoid to lose the melody of the track. I extracted the loop and I sampled it, but the Master Tempo (Time Stretch) seems to have not effect on the loop. How can I record loops and sample them whitout lose the Master Tempo feature?.
I'm using with the VDJ 3.2
Thanks in advance.
Thanks in advance.
geposted Fri 07 Apr 06 @ 4:11 pm
Hi,
yeah the timestretch doesn't apply to the sampler section I'm afraid... What you could do is timestretch the track, then use the built in recording function in vdj to create a new mp3 that is at the speed and pitch that you wanted, then play back that recording and create your loops and sample them from that...
geposted Fri 07 Apr 06 @ 8:26 pm
Hi,
I discovered exactly the same solution some hours before. Thanks a lot anyway.
geposted Fri 07 Apr 06 @ 9:00 pm
Ah well, they say great minds think alike... ;-)
geposted Fri 07 Apr 06 @ 9:42 pm
