Hi
I've hooked up a Maya 44 to my laptop and connected in my Numark CDN95 CD player. The timecode signal is 100%, and the CD player controls VDJ fine.
But I get a very high pitched whine/hum which only starts when I start the timecode CD. This suggests to me that it isn't an earth hum - but maybe I'm wrong. I'm reluctant to start connecting earths between the CD and the laptop.
I'm sure there is a simple solution, just wish I knew what it was. Hope someone can help!!
Cheers
Asymptote
Cheers
Asymptote
geposted Fri 07 Apr 06 @ 10:43 pm
you need to mute the input monitor.
geposted Fri 07 Apr 06 @ 10:45 pm
DJ Cyder
Thank you - You are an absolute Star.
Thanks - Hope I see you somewhere sometime so I can buy you a drink.
Andy
Andy
geposted Fri 07 Apr 06 @ 10:53 pm
is necessary to ground the cd players to pc? cause I'm having some problems with tccds, vdj doesn't recognize cue points, only pitch,pitch bend, play-pause, but not cues.
geposted Fri 07 Apr 06 @ 11:42 pm
