i have a sound clip of a badass flanger or jet effect if there is anyway you can hear it (when emailed) can you tell me the settings on the jet or flanger PLEASE
geposted Sat 08 Apr 06 @ 7:21 am
if fact, jet and flanger are the same effect: they add a copy over the initial song with a very little delay (less than 12 ms)
the difference between jet and flanger is :
jet: the delay does not change (except if you modify the parameter)
flanger: the delay increases and decreases according a cycle defined in beats.
look at jetlag effect, you can try flanger and jet. you will hear the difference easily.
geposted Sat 08 Apr 06 @ 9:42 pm
well then listen to this sound clip and tell me if vdj has it
geposted Mon 10 Apr 06 @ 3:51 am
Why is Traktor3's falnger so much different from the one provided with VDJ? That's better, I want to make it, but I don't know the Traktor3 formula, damn! It looks the VDJ version is less "sampled", but I don't know the truth...
geposted Mon 10 Apr 06 @ 10:25 pm
Old topic from 2006 that's over 7 years old closed.
NOTE: There are a numer of good user-made jet and flanger plugins available, but you will need to purchase VirtualDJ to be able to download and use them. Standard VST plugins can also be used.
geposted Mon 30 Dec 13 @ 5:31 am
