Is there any way to load a song from the record case onto lets say player a or b without using the mouse. I would like to be able to this via a keyboard like using shift and an arrow key.
geposted Sun 09 Apr 06 @ 4:56 pm
Yes. Go under Config > Keyboard shortcuts > Browser, there you can assign your own keyboard shortcut for any browser function (opening/closing directories, browsing up/down through song list, loading the track on a deck, etc.).
Regards.
Regards.
geposted Sun 09 Apr 06 @ 5:17 pm
When I use a keyboard shortcut to load a deck that is playing, I DO NOT get a warning screan like I do if I try to load a playing deck with the mouse. It will just KILL the playing song, and load the new one.... THIS IS NO GOOD... is there a fix for this?????
geposted Wed 10 May 06 @ 3:40 am
bump... any help???
geposted Thu 11 May 06 @ 6:16 pm
Hi,
1- It's normal, keyboard shortcut by pass any protection, it's same as a button on the skin
2- In the shortcut option, don't choose "load on active desk..." or create 2 shortcut, one for deck A and the second for deck B
geposted Thu 11 May 06 @ 6:30 pm
if u have a controler u can use that
geposted Thu 11 May 06 @ 7:31 pm
