hi, just recently i opened up task manager and found that when vdj is loaded, it's using 20% cpu even tho i havnt done anything with it yet (like loading a song, analysing songs, or playing songs). not sure what the prob is. anyone else experiencing the same?
jas
jas
geposted Tue 11 Apr 06 @ 1:39 am
Please post your computer specs (Processor, RAM, HDD)
geposted Tue 11 Apr 06 @ 1:26 pm
Hi, it's a laptop Dell 8100, Pentium III 1.0GHz 512MB RAM 20GB of HD (4GB free). Attached Maya44 sound card using TCV/turntables. i think it didnt have this cpu usage issue in previous version, althought i didnt check after every update. another new issue is when i play one song on one deck and drag a song to load up in another deck, it has this hickup, like a half sec freeze. has new version of vdj raised the requirement of hardware?
jas
jas
geposted Mon 24 Apr 06 @ 2:07 am
It is not really great computer to run VDJ, but it should work without freezing and this problem with cpu. Did you install any program till last version of VDJ which works well?? Maybe you should try optimizing the system (see my blog or other's if you want in different language).
geposted Mon 24 Apr 06 @ 6:14 am
hmm i was thinking to reinstall the whole system, start clean too. it's been 4 years since i first got the laptop and i hav never reinstalled the OS.
j
j
geposted Mon 24 Apr 06 @ 7:13 am
lol so try to do it ;)
geposted Mon 24 Apr 06 @ 10:53 am
Yes, after 4 years, you should try this first ! :-)) You make me think I should to do the same, my laptop is crying in pain when I start VDJ these days...
geposted Mon 24 Apr 06 @ 10:58 am
