Hi!
Don't know if this is the right place to ask this but i am losing my marbles!!!!!!!
I have a D-Vinyl 2020 Controller with all the software but i am having a NIGHTMARE installing the drivers for the controller, for some reason instead of installing the D-Vinyl 2020 A driver file and then the D-Vinyl 2020 B driver file, it just keeps wanting to install the D-Vinyl 2020 B file twice???
It will not do it any other way?
I am running the controller through the usb port on my Samsung V25 Laptop, it is a P4 2.8ghz with 512kb of RAM,
I have trawled the net for 2 weeks now every night trying to find a solution, you guys on here all seem to be quite helpfull and i really could do with some help/advice!
Please Please Please Help!!!!
Djstu4u
Djstu4u
geposted Tue 11 Apr 06 @ 10:20 pm
Bump
geposted Wed 12 Apr 06 @ 7:49 pm
Please can anyone help?
If i can get it working, i am looking to purchase Virtual DJ, if not then i cannot buy Virtual DJ, i really want to use this software with this controller!
Please
Please
geposted Tue 18 Apr 06 @ 6:40 pm
Are u using windows XP ?
If yes , Try following the GUIDE from the D-vinyl2020
Manually assign the HARDWARE to USB composite device (Manually update the drivers)
Since trial version only limited to one Soundcard , You can't use ASIO from the D-vinyl2020 Hardware . But u can use it as a controller . You have to enable it from the menu .
geposted Sun 23 Apr 06 @ 12:42 am
