Hi - I just downloaded the DAC3 Mapper and yes it does offer more functions. Do you have what the update provides? Now, I seem to not be able to scratch. Not sure if I'm missing a button to activate it.
geposted Wed 12 Apr 06 @ 8:20 pm
Take a look at the DAC3Mapper text file that should be in the .ZIP file you downloaded. This explains all the features of the DAC-3 mapper and what each button does.
By default the jogwheel does a fine pitch bend when playing (Ideal for fine adjustments when manual beat matching, and creates a less audible effect if you accidentally knock the jogwheel while the music is playing!)
You can scratch by holding down the [CP] button and moving the jogwheel, or you can press [CP]+[MATCH] to toggle scratch on/off (Allows you to scratch with jogwheel without holding down [CP].)
geposted Wed 12 Apr 06 @ 11:20 pm
