I keerp getting the error error in the asio sound driver. Not enough channels please advise.
I have audiotrak44 maya 44 soundcard and a 3 channel mixer. What is wrong with the setup?
geposted Sat 15 Apr 06 @ 4:30 pm
Your computed doesn't recognize your sound card (maya44). You have to remember to which port did you plug maya44 when you install it. It works only at usb port in which was pluged before. Try to change usb port or uninstall and install it again and remember the port.
and bay the way how will you use your vinyls if you don't have software??
geposted Sat 15 Apr 06 @ 6:15 pm
I have the trial...will only get the prop if I can get it to work though. Can't spend 150$ for nothing you know.
I am having so much trouble with drivers....not sure what to do.
Am I looking for a asio4all or maya driver?
S
S
geposted Sat 15 Apr 06 @ 10:49 pm
ASIO is disabled in the demo version and only 1 deck is allowed to test the TCVs.
In the full professional version you will have access to use the ASIO soundcard as well as both turntables/cd players.
Best Regards
DJ White Devil
Best Regards
DJ White Devil
geposted Sun 16 Apr 06 @ 12:17 am
So I can't do the setup with the demo version? I thought I could try one turntable out...and if it does..buy the pro version to get the 2nd one working.
geposted Sun 16 Apr 06 @ 12:32 am
