on the vdj xp10 you can set the buttons on the hardware to do what you want in the software, is this the same with the eks version ( IF THE EKS VERSION CANNOT DO THIS I NEED TO FIND SOMEWHERE WHERE I CAN THE THE ONE FOR VDJ)
geposted Sun 16 Apr 06 @ 7:28 am
Yes, you can do it the same with EKS version. Works well ;)
geposted Sun 16 Apr 06 @ 10:25 am
