Has anybody else seen this error message? I'm getting it every time I launch Virtual DJ. I have the latest Windows DirectX driver installed, but I'm still getting it. It doesn't seem to affect the performance of the program, but I'd still like to figure it out just in case.
geposted Wed 19 Apr 06 @ 10:28 pm
the error message is usally a bit misleading...
it simply means that your soundcard settings are wrong.
Check your soundcard settings in Virtual DJ, and correct it... restart, and error message should be gone.
You can still get VDJ to run perfectly, even though the soundcard setting is wrong, and you do get the error message, simply because VDJ tries the default soundcard if the choosen settings are incorrect.
geposted Wed 19 Apr 06 @ 10:32 pm
Thank you! I'll give that a shot.... =)
geposted Wed 19 Apr 06 @ 10:49 pm
