Why i Dont Have Revers In Version 3.2?
geposted Thu 20 Apr 06 @ 12:53 am
I don't understand the question? Are you a licensed user or are you using the trial, as the most recent version is 3.4.
geposted Thu 20 Apr 06 @ 12:56 am
he is trying to use timecode cd, on Technics decks..
But he does not get sound from VDJ when moving backwards...
Anybody know what that can be? I dont have any such issues
By the way, I hope you're not using a cracked version. They dont work right, and have bugs... :)
geposted Thu 20 Apr 06 @ 1:03 am
I Use The Trial 3.4 With Timcode CD & Technics sldz1200,When I Push Play In My Sldz The Music Start
But When I Touch The Platter And Spin It Back, The Sound In The Softwear Dont Come Back...Its Bleep Forward...What To Do?
geposted Thu 20 Apr 06 @ 1:06 am
Have you got master tempo (or some similar feature) turned on? A user posted a video demonstrating the Denon vs Technics vs Pioneer earlier and the Technics deck had horrible digital distortion.
Does your deck have a reverse play function. If so, does it play backwards with VDJ if you use this but don't touch the platter?
geposted Thu 20 Apr 06 @ 1:14 am
Nothing Is Turned On....No Master Tempo Or Somthing...
When I Turn The Revers On In My Deck,My Deck Turn Back But In The Vdj The Music Keep Going Forward
In My Pc It's Work Fine!
My Tech's Is With The Latest Update 2.3!
geposted Thu 20 Apr 06 @ 1:29 am
I'm not sure i am fully understanding the problem but if your do a backspin or reverse on the deck and the sound is muted during backwards play then check to see if you have the scratch assist button/plugin selected.
geposted Thu 20 Apr 06 @ 3:54 pm
When I Backspin The Sound Is Not Mute ! Its Bleep Forward ! When I Stop The Platter With My Fingers The Music Stop...
What Is The Scratch Assist & Where Its Found ?
geposted Thu 20 Apr 06 @ 5:37 pm
He's having the same problem I am. It constantly goes forward. If you try to move it backward by hand it still goes forward. It won't seem to go backwards, just forward. Like if you're trying to track backward to a spot it just keeps going forward.
geposted Fri 21 Apr 06 @ 8:49 am
Yes..... But In My PC Its Work Fine....
geposted Sun 23 Apr 06 @ 10:45 am
