Can anyone tell me if I was to analyse all the tracks on my pc, then transfer them to my DJPC, would the copy of VirtualDJ on DJPC still recognise that the tracks have already been analysed. Or would I have to re-analyse them on DJPC. The file path extensions are all set up identical!
Also...is it beneficial to analyse all the tracks before a disco?
Thanks.
Thanks.
geposted Sat 05 Jun 04 @ 2:56 pm
As I have understood, as long as the path is 100% the same, you don't have to analyze them agian... :)
And - if I understand you right, it is a huge pluss to analyze all files before you DJ at a disco. Because then u have bmp for all filels... And can sort songs by bmp, building up a dancefloor.
Dj in norway
Dj in norway
geposted Sat 05 Jun 04 @ 3:30 pm
need to transfer the database too
geposted Sun 06 Jun 04 @ 12:38 pm
I would analyze all files and then put them into a 4 beat loop to check for sync before I would go into a club and put it to work.
I have seen the BPM calculator work, I have seen it not work. I have seen sleeves with BPMs listed that were wrong.
Best bet is to take the songs you will know you will want to mix and tap them out, but ALWAYS check them in a 4 beat loop before going live with a mix.
geposted Mon 07 Jun 04 @ 6:36 pm
true...very true rick...
Fruit made an excellent guide "how to find right BMP"..
https://virtualdj.com/forum/display.html?topic=2509
The more songs u "correct" - the better is the DJ set gonna be :) a little work, but worth it!
dj in norway
dj in norway
geposted Mon 07 Jun 04 @ 8:33 pm
