Is there any way to play songs in the record case unattened for continous play.. for example im at a wedding doing the cocktail party and would like to mingle with the guest but cant because i have to attend to VDJ and load the songs onto each ttb. What a bore...
geposted Sat 22 Apr 06 @ 10:41 pm
Yep! I do wedding too, and without autoplay life would be a little more tedious...
Just put the songs you wish to autoplay into the playlist on the right side of the screen. Hit the star button and it will load the decks and start playing right away. It's perfect for cocktail/dinner music!
You probably want to adjust your settings so that it will not cut your songs in strange ways: go to your congfig menu, and on the FAME tab set your crossfader to "full" and your fade length to 2 seconds. That should do it!
geposted Sun 23 Apr 06 @ 2:57 am
Thanks for the tip
geposted Sun 23 Apr 06 @ 4:15 am
